Why the compilation report didn't display the resources usage when I made the verilog file as top file?
- 7 years ago
Hi 11000,
Synthesizer removes all logic whose outputs are unused.
You have have to route out some outputs otherwise the synthesizer will remove all of the logic.
Anand
Hi AnandRS,
Thanks to your advice, I checked every module 's input and output pins the whole day. At last I made it out by ensuring every module has valid ports. It was really difficult for me to design the top file in verilog while my project had about ten modules. But I also think the bdf file would be complex and unclear in this situation.
Is there any better way for me to design the top file?
Thank you a lot.
Hi 11000,
To view the resource you can add dummy ports in your module and connect it's output ports.
If we do so we can see 1-PLL being used.
Example:
`timescale 1 ps / 1 ps
module top (
input wire clk,
input wire reset,
//dummy ports
output wire locked_sig ,
output wire outclk_0
wire areset_sig ,clk_ms ,clk_ad;
PLL PLL_inst (
.areset ( areset_sig ),
.inclk0 ( clk),
.c0 ( clk_ms ),
.c1 ( clk_ad ),
.locked ( locked_sig )
endmoduleRegards
Anand
