7 years agoWhy the compilation report didn't display the resources usage when I made the verilog file as top file?
I used a PLL to produce clock, but it didn't display the resources usage when I made the verilog file as top file. But when i set the bdf file as top file it worked. Is there any mistakes in my top ...
- 7 years ago
Hi 11000,
Synthesizer removes all logic whose outputs are unused.
You have have to route out some outputs otherwise the synthesizer will remove all of the logic.
Anand
Abe
7 years agoConnect the areset input pin to the PLL from the system rst and you can also use an internal wire for the locked pin
wire pll_locked;
PLL PLL_inst (
.areset ( rst ),
.inclk0 ( clk0 ),
.c0 ( clk_ms ),
.c1 ( clk_ad ),
.locked ( pll_locked )
