MBark9
7 years agoWhy Quartus 18.1 Lite can not run inside an LXD container?
I've installed Quartus 18.1 Lite in an LXD container (on Ubuntu 18.04). Unfortunately, it can not run, always crashes with one of the following errors: fpgabuild@fpgabuild:~$ quartus quartus: mallo...
RichardT_altera
7 years agoI found a discussion about malloc failing. Could be memory allocation failed when data segment is invalid or the system is low on memory?
https://stackoverflow.com/questions/12433947/why-does-malloc-not-work-sometimes
You can use the valgrind memory error detector to help you find these kind of errors.
