sli30
8 years agoWhy logic utilization is much higher?
Dear all, This is my estimated resources on Arria 10. I used Quartus v17.1. The logic utilization is much higher than ALUTs, registers, memory and DSP. Is this normal? Because the other resources ar...
Tricky
8 years agoLogic utilisation is a function of your code. So why were you expecting more Mem and DSP usage? have you checked the per-entity logic usage to see if entities where you expected ram are using logic instead? This will usually occur when you have code that cannot infer rams or DSP.
