Anonymous
7 years agoNot applicable
Why does vsim occasionally crash with ERROR CODE 4 when using Quartus Prime Lite (no license required)? How can I solve this problem?
PROBLEM: vsim occasionally crashes with error code 4. TRANSCRIPT: FATAL ERROR: Unable to read lock file necessary for use of uncounted nodelocked license. Exiting. SOFTWARE VERSION: ModelS...
Anonymous
Thanks for your responses,@HRZ @AndyN .
- The Modelsim install is the Intel FPGA Starter Edition v10.5b, and the projects are well less than the 10k line limit.
- It appears to fail at random, with exit code 4.
- Per the Modelsim user manual, exit code 4 is a license issue.
- This is consistent with the fatal error that shows up in the transcript.
