Anonymous
7 years agoNot applicable
Why does vsim occasionally crash with ERROR CODE 4 when using Quartus Prime Lite (no license required)? How can I solve this problem?
PROBLEM: vsim occasionally crashes with error code 4. TRANSCRIPT: FATAL ERROR: Unable to read lock file necessary for use of uncounted nodelocked license. Exiting. SOFTWARE VERSION: ModelS...
AndyN
7 years agoBy any chance, is it failing when you re-run it after a successful run? I've had issues with some Modelsim sub-processes not getting properly terminating when running on Linux (which then gives weird behavior when you then re-run).
Andy
