JBrod6
7 years agoWhy does the Platform designer On-Chip Flash Intel FPGA IP memory map differ from the .rpd file map generated by the Convert Programming File tool. What address should be used to program the CFM? MAX10 device - 10M40DCF256C8G
This is the map from the IP: This is the map from the rpd .map file: BLOCK START ADDRESS END ADDRESS ICB 0x00000000 0x00001FFF UFM 0x00002000 0x000B9FFF CFM0 0x000BA000 0x00161FFF...
ShafiqY_Intel
7 years agoHi JBrod6,
The .map file memory map is differ from On-Chip Flash Intel FPGA IP memory map because .map file is add ICB information in pof file.
In On-Chip Flash Intel FPGA IP, UFM start at 0x00000000.
In .map file, UFM start at 0x00002000
0x0-0x1FFF is used for ICB information. Thus, UFM need to start at 0x2000.
I hope this is clear.
Thanks😉
