RMees
7 years agoWhy does Signaltap insist on recompile after recompile?
This happens regularly : In a design with working signaltap probes. I add or remove a few signals and recompile. After a full build I start up signaltap and it reports : Start Rapid Recompile to ...
RMees
7 years agoI ALWAYS do a full compile, NEVER rapid compile, see previous response.
This state remains the same if I dont touch ANYTHING :
- I start signaltap.
- Signaltap indicates a recompile is required.
- I close signaltap
- I run a full compile
- I start signaltap
- I close signaltap
- I start signaltap
- I close signaltap
- I start signaltap
etc...
If there was a change in the source files the recompile would have taken care of that.
I think there is a file that Quartus generates that is in a bad state.
Quartus/Signaltap is checking something to make this decision.
What is it?
If you are an expert on this tool you should be able to answer that question.
