RMees
7 years agoWhy does Signaltap insist on recompile after recompile?
This happens regularly : In a design with working signaltap probes. I add or remove a few signals and recompile. After a full build I start up signaltap and it reports : Start Rapid Recompile to ...
KennyT_altera
7 years agoRapid recompile usually take in if there are changes in the source code or changes on the stp files.
Can you try to just make a simple compile and look for if there are any code changes in the message in the synthesis?
What you can also do is create a simple design and make a signal tap run. Compare the message result in the working one and the non working one.
Let me know if this helps?
