RMees
7 years agoWhy does Signaltap insist on recompile after recompile?
This happens regularly : In a design with working signaltap probes. I add or remove a few signals and recompile. After a full build I start up signaltap and it reports : Start Rapid Recompile to ...
RMees
7 years agoI always do a full compile.
Locking the changes is not relevant since signaltap indicates that a recompile is requires as soon as signaltap loads.
When I load the design with signaltap the new signals are visible in the signal list.
I have closed signaltap and quartus.
I have deleted the db and incremental_db directories.
I have deleted all directories generated by qsys.
I have checked out the source files from git and rebuild from scratch.
Nothing works.
Quartus/Signaltap is checking something to make this decision.
What is it?
