9 years agoWhy does one single load/store consume much RAMs?
Hi, when I design OpenCL and run aocl, it reports that one single load consume 13 RAMs and one single store consume 16 RAMs. e.g __kernel void top_kernel(__global restrict volatile int *a,...
9 years ago --- Quote Start --- Considering the very low memory bandwidth on current FPGA boards and the very high overhead of contention for off-chip memory accesses, you should actually avoid having parallel memory accesses and instead, unroll your memory accesses in a way that they will be coalesced into bigger ones, to minimize the number of ports to external memory. These ports, as you have noticed, waste a lot of space on the FPGA. In your code example, you are unrolling the i loop, while the memory accesses are not contiguous over the i dimension and hence, you get 64 memory ports. This, apart from very high area usage, will lower your memory bandwidth to near-zero due to constant contention between all those ports. However, if you partially unroll the j loop 64 times, since the accesses are contiguous, you will get a few large coalesced ports with very low area overhead, and you will get very close to theoretical memory bandwidth. --- Quote End --- I totally agree with your suggestion. I have tried and it works. Thanks.
