9 years agoWhy does one single load/store consume much RAMs?
Hi, when I design OpenCL and run aocl, it reports that one single load consume 13 RAMs and one single store consume 16 RAMs. e.g __kernel void top_kernel(__global restrict volatile int *a,...
9 years ago --- Quote Start --- Other than disabling the cache using volatile, there is nothing else that can be done. Is there a specific reason you want to do this? Removing those FIFOs will have a very large negative impact on performance. --- Quote End --- I also saw that using volatile can disable the cache. I want to apply coarse grained parallel on external memory access, e.g. # pragma unroll for (i = 0; i < 64; ++i) for (j = 0; j < 1000; ++j) ... = a[i * 1000 + j]; It will consume a lot of RAMs (64 * 16 RAMs) while total of RAMs is about 2700 RAMs in arria10. After that, we have little optimization space because of lack of RAMs. Thanks.
