NSriv2
7 years agoWhy does aoc compiler increase the channel depths from the once that are specified? Is there a way to fix the code to prevent that?
Hi, I have seen many cases in which I specify the channel depth as: channel drain_struct _A_feeder_0_channel[_II_][_JJ_-1] __attribute__((depth(0)) But the compiler increases the channel depth t...
NSriv2
7 years agoThanks HRZ. I have cases where channel depths are increased by more than 1 unit as well. I didn't understand your "false cycle" suggestion. Can you please elaborate on that?
