Why do I get this Synthesis error?
I am building a variant of a working project, using Quartus Prime Lite.
It fails Analysis & Synthesis right at the end (97%).
I have tried in V17.1.0 and 18.1, same error with both.
It occurred after I modified an Avalon FIFO memory component in my qsys system.
When I compare the sdc file from this project with my earlier successful project, only the project names (my_proj) are different.
Any Ideas/workarounds?
Thanks John.
Info (332104): Reading SDC File: 'd:/sandbox/wh/db/ip/my_proj/submodules/my_proj_fifo_0.sdc'
Error (332000): ERROR: You must open a project before you can use this command.
while executing
"get_names -entity $search_entity -filter * -node_type hierarchy"
(procedure "altera_private_get_entity_instances::find_instances_of_entit..." line 14)
invoked from within
"altera_private_get_entity_instances::find_instances_of_entity $entity_name $nowarn"
(procedure "get_entity_instances_internal" line 72)
invoked from within
"get_entity_instances_internal 0 my_proj_fifo_0"
invoked from within
"get_entity_instances $entity_name"
(procedure "apply_sdc_pre_dcfifo" line 3)
invoked from within
"apply_sdc_pre_dcfifo my_proj_fifo_0"
(file "d:/sandbox/wh/db/ip/my_proj/submodules/my_proj_fifo_0.sdc" line 82)
Does your project use any DCFIFO IP blocks, If so delete the component, create a new instance and try building it again.
- John
Hi Vikas,
Deleting DB & Incremental_db folders did not fix the issue.
Thankfully Abe's suggestion of deleting the DC-FIFO component and creating a new one did fix it.
Thanks to everyone for the helpful suggestions.
John.
- JOHI
Contributor
Sometimes you need to clean your project + delete all generated files before recompiling.
A mixup can occur where the quartus menu command "project/clean" is an option or even manually delete automatically generated subdirectories.
(I had it before that the output of 2 qsys generations with small modifications between 2 versions mixed things up. Cleaning things up got me back on track.)
Johi.
- Vicky1
Hi John,
Try to recompile by deleting the 'db' & 'incremental_db' folder from project generated directory.
Best Regards
Vikas Jathar
- Abe
