18 years agoI know NIOS II kits reset itself after configuration if you set the unused pins to drive ground. This is because the nConfig pin is tied to one of the unused IO. Not sure what happened to yours if it reset because of connection to PC using ethernet.
Maybe you can try to set the unused pins to be input tri-stated and see if it helps. Driving ground sometimes draw a lot of current as well if you have pull up resistors to the unused pins.
