16 years agoioriveur,
i'm now in windows system, and i remember the default installing location is /opt/altera9.10/ And the launch binary should be /opt/altera9.10/quartus/bin/quartus if I don't make a mistake. you said that you have installed it in a removable HDD? You had to at least remember the location you have installed. It should be in the similar place. HDD path is mostly located in /media/[HDD label name]/blabla(i'm ubuntu 9.10), if you locate the installing path, i'm sure you can launch quartus easily.
