DBay's avatar
DBay
8 years ago
Why are partitions not supported anymore?
It used to be that you could have multiple levels of partitions and LL regions. Now with the latest software, you can no longer do anything but a flat design as Quartus 18 will crash or see conflicting assignments when there are none. Usually it just crashes. If partitions are no longer a supported function, then please remove it from the menu options.
  • DBay's avatar
    DBay
    No, it is ITAR/military. You don't support that code.
    LL regions are also not supported in pro for import/export. At least no one appears to know how to do it.
    WHen you use standard, it just crashes. So, it may be documented, but still unusable.
