11 years ago`For clarity (please do this the next time you post code as well)
This is how your code now looks?library ieee ;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity alu_control is
port(
ALUOp: in std_logic_vector(1 downto 0);
Funct: in std_logic_vector(5 downto 0);
ALUCtrl: out std_logic_vector(3 downto 0)
end entity alu_control;
architecture alu_control_arch of alu_control is
begin
process (ALUOp, Funct, ALUCtrl)
begin
case ALUOp is
when "00" =>
if Funct = "xxxxxx" then
ALUCtrl <= "0010";
end if;
when "01" =>
ALUCtrl <= "0110";
end if;
when "10" =>
if Funct = "100000" then
ALUCtrl <= "0010";
elsif Funct = "100010" then
ALUCtrl <= "0110";
elsif Funct = "100100" then
ALUCtrl <= "0000";
elsif Funct = "100101" then
ALUCtrl <= "0001";
elsif Funct = "101010" then
ALUCtrl <= "0111";
else
ALUCtr <= "xxxx";
end if;
when others =>
ALUCtrl <= "xxxx";
end case;
end process;
end architecture alu_control_arch;
