9 years agoWhy a warning occurred when I made the opencl example-"board_test" for DE1-SOC
I am running some opencl project examples with de1-soc,and I have problem when I make the host program of "board_test"(the example provided by ALTERA). As shown in the picture below,a warning o...
9 years agoIf you are cross-compiling for an ARM SoC, you should have the ARM libraries in your path. You should NOT copy the library file to your existing LD_LIBRARY_PATH, you should add the path to the library file to LD_LIBRARY_PATH; there might be other libraries in the same path that are needed for correct compilation/linking. You should also add the path to the library file in the BSP that is provided by the board manufacturer to LD_LIBRARY_PATH.
