12 years agoHi,
I also switched to QII 13.0 and have no issues. Thus the SignalTap itself is working, but that does not solve your Problem. At least the aaa.stp is the correct file. A Long time ago I had - never discovered why - some issues, that the *.sof download from within the SignalTap window failed and I had to download via the normal programmer... Finally - QII 13.0 creates an "output files" directory where the *.sof is located by standard configuration, QII 12 did store these files in the normal project directory. Maybe - if you just Switch to QII 13.0 you are still using the *.sof in the normal Project Directory which is outdated? Maybe it's worth to check for *.sof in the Project Directory (including subdirs) to locate the newest one.
