13 years agoit's my first time to use signaltap, could you teach me how to use it in this situation
setup i add SW[0] , right hand side i choose clock as CLOCK_50, trigger use pre-trigger and condition 1 and sequantial trigger in i use rising_edge and SW[0] then i try to press read data , said trigger condition not met in SW[0] in central part then i press analysis, it do not have response , i got a question when doing it in signaltap, there is no output parameter in top layer, how can signaltap see the data, if i need to add back eth0 as output parameter in top layer, how to connect them with this Triple speed IP when data is just 4 bits
