14 years agoIn the first one you are using intermediate signal x then registering the output from x.
In the second one you register output directly thus eliminating 8 registers between x and output. Both are correct functionally but I don't quite get your timing report. The second one should be enough unless - in a large project you get timing violations and may opt for extra registers.
