12 years agowhere is my fault in this code?
when I attempt to simulate the design This warning is displayed:
warning: daggen_0523: the source is compiled without the -dbg switch. line breakpoints, code coverage, and assertion debug will not be available.where is my fault?
library IEEE;use IEEE.std_logic_1164.all;
use IEEE.std_logic_unsigned.all;
entity RAM_1 is
generic ( M : natural:=8 ); -- depth=2**N
port( clk : in std_logic; -- clock
cs : in std_logic; -- chip select
rw : in std_logic; -- read=0/write=1
addr : in integer; -- address
data : inout std_logic_vector(7 downto 0)); -- data
end entity RAM_1;
architecture RTL of RAM_1 is
type mem_array is array (0 to M**2-1) of std_logic_vector(7 downto 0);
signal ram : mem_array:=( X"06",X"02",X"0A",X"06",X"05",X"03",X"07",X"09",
X"02",X"01",X"00",X"06",X"08",X"0B",X"04",X"0F",
X"02",X"01",X"00",X"06",X"08",X"0B",X"04",X"0F" );
begin
process
begin
wait until ( CLK'event and CLK='1');
if cs='1' then
if rw='1' then
ram(addr) <= data;
else
data <= ram(addr);
end if;
else
data <= (others=>'Z');
end if;
end process;
end RTL;
