9 years agoWhen to reset a signal.
In one process I set a command
when X"01" => --continious data read
cont_ram_addr := to_integer(unsigned(addr_bus));
ram_command <= RAM_CONT_WRITE;
when X"02" => -...
9 years ago --- Quote Start --- Like I said in your other post, you need to communicate between processes with signals. Create a signal for the sole purpose to send a message between the processes that can reset you ram_command signal. --- Quote End --- But who reset the other signal - the one that reset ram_command? And when? Thanks guys. Stupid question. I figured it out.
