9 years agoWhen to reset a signal.
In one process I set a command
when X"01" => --continious data read
cont_ram_addr := to_integer(unsigned(addr_bus));
ram_command <= RAM_CONT_WRITE;
when X"02" => -...
9 years ago --- Quote Start --- That's the problem. I'd gladly reset ram_command in the second process. But I get Error (10028): Can't resolve multiple constant drivers for net. So I dont know when I'm good to reset the signal. --- Quote End --- Like I said in your other post, you need to communicate between processes with signals. Create a signal for the sole purpose to send a message between the processes that can reset you ram_command signal.
