9 years agoWhen to reset a signal.
In one process I set a command
when X"01" => --continious data read
cont_ram_addr := to_integer(unsigned(addr_bus));
ram_command <= RAM_CONT_WRITE;
when X"02" => -...
9 years agoLooks like you either need to incorporate the command setting logic into the command executing state machine, or at least you need the state machine to be able to communicate with the command setting logic (to reset the command or whatever you need to make the design work). As Tricky said, very hard to give advice from such little information.
