--- Quote Start ---
I'm also assuming the VALID signal is synchronous to the CLK clock domain. If not you need to synchronize it first.
--- Quote End ---
Valid is an input. I'm not sure what you mean by, is it synchronous. I assume it is.
Here's what ended up working:
library ieee;
use ieee.std_logic_1164.all;
--This file is responsible for reading in frames and storing them
entity FrameHolder2 is
port
clk,reset: in std_logic;--clock and reset inputs
input: in std_logic;--the serial input on which the ethernet frames arrive
valid: in std_logic;--the valid signal which lets us know when an ethernet frame is valid
startout: out std_logic;--a test output to let us trace when we are storing ethernet information
storeout: out std_logic;--a test output to let us know when we would commit the stored data
output: out std_logic--the output ethernet stream
end FrameHolder2;
architecture structure of FrameHolder2 is
signal prehold: std_logic_vector(63 downto 0);--holds the preamble
signal start: std_logic;--lets us know if we're ready to start storing the ethernet frame
signal reg: std_logic;--temporary register to help detect when valid goes to '0'
signal valid_fe: boolean;--valid falling edge, lets us know when valid goes to '0' from '1'
component rshift8byte is --8 byte right shift register for holding onto the preamble
PORT
aclr : IN STD_LOGIC ;
clock : IN STD_LOGIC ;
enable : IN STD_LOGIC ;
shiftin : IN STD_LOGIC ;
q : OUT STD_LOGIC_VECTOR (63 DOWNTO 0)
end component;
begin
process (clk, reset)
begin
if (reset ='1') then
reg <= '0';
elsif (clk'event and clk='1') then
reg <= valid; --this detects when valid goes from '1' to '0'
end if;
end process;
stage0: rshift8bit port map(reset,clk,not start,input,prehold);
--stage1: something port map(reset,clk,start and valid,input,something);
valid_fe <= reg='1' and valid='0'; --detects when valid goes from '1' to '0', we need to do this
--because valid goes high at some point during the preamble, and goes low when the frame is received.
--We need to know when we are done receiving a frame and this occurs on the falling edge of valid.
start <= '1' when prehold = "1101010101010101010101010101010101010101010101010101010101010101" and not valid_fe else '0';--start storing the ethernet frame until we get a falling edge of valid
storeout <= '1' when valid_fe else '0';
startout <= start;
end structure;
I'm using valid_fe as a boolean in this case
