Ok, I think I understand how it should work, but I don't understand why it still doesn't work. The process statement makes it so that the reg stores the value of valid, and then you're comparing the old value of valid with the new value of valid so you detect the falling edge. Here's how I tried to implement it, but it doesn't work:
library ieee;
use ieee.std_logic_1164.all;
--This file is responsible for reading in frames and storing them
entity FrameHolder2 is
port
clk,reset: in std_logic;--clock and reset inputs
input: in std_logic;--the serial input on which the ethernet frames arrive
valid: in std_logic;--the valid signal which lets us know when an ethernet frame is valid
startout: out std_logic;--a test output to let us trace when we are storing ethernet information
storeout: out std_logic;--a test output to let us know when we would commit the stored data
output: out std_logic--the output ethernet stream
end FrameHolder2;
architecture structure of FrameHolder2 is
signal prehold: std_logic_vector(63 downto 0);--holds the preamble
signal start: std_logic;--lets us know if we're ready to start storing the ethernet frame
signal reg: std_logic;--temporary register to help detect when valid goes to '0'
signal valid_fe: std_logic;--valid falling edge, lets us know when valid goes to '0' from '1'
component rshift8byte is --8 byte right shift register for holding onto the preamble
PORT
aclr : IN STD_LOGIC ;
clock : IN STD_LOGIC ;
enable : IN STD_LOGIC ;
shiftin : IN STD_LOGIC ;
q : OUT STD_LOGIC_VECTOR (63 DOWNTO 0)
end component;
begin
process (clk, reset)
begin
if (reset ='1') then
reg <= '0';
elsif (clk'event and clk='1') then
reg <= valid; --this detects when valid goes from '1' to '0'
end if;
end process;
stage0: rshift8byte port map(reset,clk,not start,input,prehold);
valid_fe <= '1' when reg = '1' and valid = '0'; --detects when valid goes from '1' to '0', we need to do this
--because valid goes high at some point during the preamble, and goes low when the frame is received.
--We need to know when we are done receiving a frame and this occurs on the falling edge of valid.
start <= '1' when prehold = "1101010101010101010101010101010101010101010101010101010101010101" and valid_fe = '0' else '0';--start storing the ethernet frame until we get a falling edge of valid
storeout <= '1' when valid_fe = '1';
startout <= start;
end structure;
Thanks for the help
