14 years ago
when printed "quartus_sh --qhelp" in tcl console,quartus ii occured an error
Error:invalid command name "quartus_sh"
Error: while executing
Error:"unknown_original quartus_sh --qhelp"
Error: ("eval" body line 1)
Error: invoked from within
Error:"eval unknown_original $cmd $args"
Error: (procedure "::unknown" line 7)
Error:"quartus_sh --qhelp"
I checked the packages that loaded and found the package "project" was not loaded yet. I printed "load_package ::quartus:: project -version 6.0 " and got an error again: Error:ERROR: Tcl package "::quartus:: project" does not exist. Specify an available Quartus II Tcl package. Type "help" for a list of available Quartus II Tcl packages. I am new in using tcl and I can't figure this out.
how can I run executables like quartus_fit, _map and so on in tcl console?
Any thoughts on this issue are appreciated.
    I run quartus_sh --qhelp from a command prompt(dos or Unix), not within a Tcl console. I think you can do:
    execute_module -tool fit
    In general, I don't see users running tools within the Tcl console. Instead they do it in scripts that run when the GUI is closed.
    Thank you very much. Now I can run those executables with command prompt(dos). But when I tried to run a script like "quartus_sh -t myscript.tcl " it printed tcl file myscript is not found. Could you please tell me is it necessary to put myscript file under a specified directory, and where is it? If not, what's supposed to be wrong with my work?
    I save my .tcl file in the same location as the project and in the command prompt cd to that location. I'm sure there are other solutions(like storing in a common location like c: and just pointing to it from the call)
    Thank you very much! How terrible my windows skill is. My problem is solved at last.
