SAbde7
7 years agoWhen is it safe to use smart recompilation?
When I turn on smart compilation and then change a parameter in the design(just a constant value stored in a register or a constant connected to combinational logic of fixed length like and adder or ...
RichardT_altera
7 years agoThis could be a bug in using the smart compilation. Can you help to share a simplified design that could duplicate this issue - causing design does not function properly after smart compilation? I will consult with the engineering team regarding this.
As you mentioned previously, please turn off the smart compilation and instead do a full compilation for the current design. I apologize for the inconvenience caused.
