SK_VA
8 years agoWhen I try to constrain the path between two FPGA pins with a skew of 2ns between max and min delay values.It time closes if i run Time quest analyser for some values.But when I run full compilation it fails with a different delay value
I am trying to constrain the max delay and min delay between an input pin and an outpin in FPGA so that under PVT conditions skew between max and min delay values be between 2-3 ns.
- mfro
I guess you should try and rephase your question.
At least I am unable to understand what you are asking.
- AndyN
What are the specific constraints that you are using? Can you share them here?
- SK_VA
set_max_delay -from [get_ports {input_pin}] -to [get_ports {output_pin}] 9.6
set_min_delay -from [get_ports {input_pin}] -to [get_ports {output_pin}] 3.2
this is the constraint I am using
- sstrell
Is there just combinatorial logic between the pins or are you trying do this across registers?
