SK_VA's avatar
SK_VA
8 years ago
When I try to constrain the path between two FPGA pins with a skew of 2ns between max and min delay values.It time closes if i run Time quest analyser for some values.But when I run full compilation it fails with a different delay value
I am trying to constrain the max delay and min delay between an input pin and an outpin in FPGA so that under PVT conditions skew between max and min delay values be between 2-3 ns.
