10 years agoWhat's wrong with my .mif file
Hi, I'm trying to initialize a ROM with a .mif file. I'm doing this for the first time, so probably there is just a simple mistake in my file. I used this guide http://quartushelp.altera.com/...
10 years agoa common problem with modelsim mif search is that it follows the path set when mif was generated. This then gets wrong relative to modelsim folder.
you can either put a copy of mif in modelsim folder or adjust the mif path to be same as that written in memory code
