10 years agoWhat's wrong with my .mif file
Hi, I'm trying to initialize a ROM with a .mif file. I'm doing this for the first time, so probably there is just a simple mistake in my file. I used this guide http://quartushelp.altera.com/...
10 years agoThe .mif file looks fine to me. I would re-generate the ROM core and re-select the .mif file when you do that. The path to the .mif file is placed as a parameter in the rtl file that is created when you generate the core, and it's that parameter that tells Quartus where to find the .mif file. I'm guessing the path or file name changed and Quartus can't find the file.
