Altera_ForumHonored Contributor12 years agoWhat's the mean of "qfbk" here? I found the words "qfbk" in several doc of altera, what's the mean? And also what the mean of below comments "Note that not all positions in a LE need necessarily be populated with a logic ce...Show More2.jpg49 KB
Altera_ForumHonored Contributor12 years ago --- Quote Start --- The path is designated "register feedback" in device handbooks. --- Quote End --- Thanks for you information!
Recent DiscussionsHow to fix Error(23782): Failed to find an expected reportMailbox Client IP - SEND_CERTIFICATE command through FPGA fabricQuartus Prime license rehosted, unable to runFailed to run ip-setup-simulation:Connection bit order between hierarchy
