9 years agoWhat's the difference between these two pieces of simple code?
Do you think there is a difference in functionality between these codes? always @(posedge clk)
begin
A<=0;
if (sel==0)
A<=in_u;
9 years ago --- Quote Start --- But how come the first one will not get an error since I am also assigning 0 to A initially. For the second case, I am just doing the same thing, but moving the resetting part to another sequential clock process. --- Quote End --- They are not the same, because the assignment to A in the first always block is always overriden, so A can only be in_u or in_v In the second one, A is always assigned to 0, but it is also always assigned to in_u or in_v. In this case, if the selected signal is 1, then the 1 drives against 0 to give X
