9 years agoWhat's the difference between these two pieces of simple code?
Do you think there is a difference in functionality between these codes?
always @(posedge clk)
begin
A<=0;
if (sel==0)
A<=in_u;
else
A<=in_v;
end always @(posedge clk)
begin
if (sel==0)
A<=in_u;
else
A<=in_v;
end
always@(posedgeclk)
A<=0;10 Replies
Yes. The first one will select between in_u and in_v.
In the second one A will be X when the selected input is 1 (and in synthesis, you'll get a multiple driver error) - Altera_Forum
But how come the first one will not get an error since I am also assigning 0 to A initially. For the second case, I am just doing the same thing, but moving the resetting part to another sequential clock process.
--- Quote Start --- But how come the first one will not get an error since I am also assigning 0 to A initially. For the second case, I am just doing the same thing, but moving the resetting part to another sequential clock process. --- Quote End --- They are not the same, because the assignment to A in the first always block is always overriden, so A can only be in_u or in_v In the second one, A is always assigned to 0, but it is also always assigned to in_u or in_v. In this case, if the selected signal is 1, then the 1 drives against 0 to give X - Altera_Forum
Okay, so that simply means:
1) Assignment in different 'always' blocks --> they are evaluated in parallel, resulting in multiple driver error 2) Assignment in the same 'always' block --> they are evaluated in sequential, where it will reset initially before going into a MUX - Altera_Forum
--- Quote Start --- Okay, so that simply means: 1) Assignment in different 'always' blocks --> they are evaluated in parallel, resulting in multiple driver error 2) Assignment in the same 'always' block --> they are evaluated in sequential, where it will reset initially before going into a MUX --- Quote End --- You need to understand the underlying hardware. 1) It generates 2 bits of logic that have both outputs wired together. Each always block creates some logic. 2) Yes - but there is no reset occuring, because the assignment to 0 is overriden and thus ignored. - Altera_Forum
Ill just clarify:
is identical to this:always @(posedge clk) begin A<=0; if (sel==0) A<=in_u; else A<=in_v; endalways @(posedge clk) begin A<=in_v; if (sel==0) A<=in_u; end - Altera_Forum
I tried both pieces of code on Vivado. Strange enough, they both passed!
--- Quote Start --- I tried both pieces of code on Vivado. Strange enough, they both passed! --- Quote End --- Not really strange - they are functionally identical. - Altera_Forum
--- Quote Start --- Not really strange - they are functionally identical. --- Quote End --- I was referring to the code in my initial post. Code# 2 failed in Quartus due to multiple driver error, but passed in Vivado - Altera_Forum
Was the project set up correctly? Was A removed?
