9 years agoWhat TCL is executed during Analysis & Elaboration stage?
Hi All, While execution of the Analysis & Elaboration stage in the Quartus Prime (v16.1.2), I'm receiving the following message in the Messages Window: "Warning (125092): Tcl Script File ....
9 years agoThe format of that path tells me that you are using a project that was archived as a .qar that, in its original location, pointed to that IP directory and the IP's .qip file. The message is referring to the .qip file as the script. The message is not generated by a script. Check the files that have been added to the project (Project menu -> Add/Remove Files in Project) and make sure the .qip in the correct location is listed there.
