What simulation script is supposed to be used with ActiveHDL Qsys simulation?
Qsys generates several scripts that are supposed to be used to start and run simulation. There is a script generated for Riviera Pro called rivierapro_setup.tcl but no script for ActiveHDL. Is the rivierapro_setup.tcl supposed to be used with ActiveHDL and is it always supposed to work in this case as well?
This implies that ActiveHDL is supposed to use the same script as riviera pro. If this is the case then this case can be closed.
- KennyT_altera
- gyuunyuu
Contributor
- KennyT_altera
You are right,
Since this thread had been answered, we shall close this thread. If you still need further assistance, you are welcome to post a response within 15days or open a new thread, some one will be right with you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
