gyuunyuu
Contributor
5 years agoWhat simulation script is supposed to be used with ActiveHDL Qsys simulation?
Qsys generates several scripts that are supposed to be used to start and run simulation. There is a script generated for Riviera Pro called rivierapro_setup.tcl but no script for ActiveHDL. Is the ri...
- 5 years ago
This implies that ActiveHDL is supposed to use the same script as riviera pro. If this is the case then this case can be closed.
KennyT_altera
5 years agogyuunyuu
Contributor
5 years agoThis implies that ActiveHDL is supposed to use the same script as riviera pro. If this is the case then this case can be closed.
