18 years agoHello,
I understand from Verilog specification, that variables only appearing in the event expression (without a posedge or negedge keyword) are ignored. If you intend an asynchronous "logic loop" latch, you should write as such. if (a | b | c | d) out=1'b1; Or out = out | a | b | c | d; The problem is, that a logic loop, unlike a flipflop has no default power-on state, so out could be high from the beginning. Cause a reset condition would be necessary in real live anyway, this is more a theoretical issue. out = (out & ~reset) | a | b | c | d; Regards, Frank
