18 years agoFor sure I'm no expert in VHDL and maybe there are more elegant solutions, but the following should work:
----------------------------------------- library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; use ieee.std_logic_arith.all; entity DDS_LUT is port ( clk : in std_logic; --encoder_a : in std_logic; data_b : in integer range 3185 to 4215 ; --std_logic_vector(12 downto 0); Hex_out : out std_logic_vector (30 downto 0) --(need output with hexa not bin) ); end; architecture arc_DDS_LUT of DDS_LUT is signal hex_out_internal : std_logic_vector (30 downto 0); begin hex_out <= hex_out_internal; -- or maybe: Hex_out (30 downto 0) <= Hex_out_internal (30 downto 0); process (clk) begin if CLK'EVENT and CLK = '1' then case data_b is when 3185=> hex_out_internal <= ("1010101101110111011101110111100"); when 3186=> hex_out_internal <= ("1010101101101001110100000011011"); when 3187=> hex_out_internal <= ("1010101101011100001010001111011"); when 3188=> hex_out_internal <= ("1010101101001110100000011011010"); when 3189=> hex_out_internal <= ("1010101101000000110110100111010"); .... and so on ----------------------------------------- Hope this helped :) Right: sensitivity list should be changed, too.
