NikoR
7 years agoWhat is the script equivalent of Quartus Prime GUI's "Export Report as HTML"?
In Quartus you can export sections from the Report file as HTML. How can you do the same when running Quartus from a script?
- 7 years ago
Thank you for your suggestions!
To summarize:
- The TCL command "write_report_panel" is limited to only tabular subsections of the report file. (Not what I wanted in this case...)
- Adding GENERATE_HTML_REPORT_FILES = 1 to quartus2.ini creates all the nice HTML report exactly as from the GUI. (Selecting Tools > Options > tick 'Automatically generate HTML-Format Report Files (.htm) after design processing' updates the quartus2.ini file). This is a global setting that applies to all your projects.
sstrell
7 years agoI forget exactly where it is, but there is a setting in the Options dialog from the Tools menu to always create an html version of the Compilation report whenever you compile the project. It gets placed, by default, in the output_files folder. As far as scripting this is concerned, check the Quartus Compilation user guide. It must have the appropriate Tcl and command line option in there.
