What is the motivation behind the creation of Data Pattern Generator/Checker Verification IP?
The Intel Quartus Prime Platform Designer contains some verification IP that contains the terms "Pattern Checker" and "Pattern Generator" in their name. These were added quite late into the IP suite provided with Quartus Prime.
The Quartus Prime already has had Avalon MM master/slave, Avalon ST source/sink BFM IPs for many years. What then is the motivation behind creation of these new pattern generator and checker verification IP? Can't the same task be performed using the existing BFMs anyway?
I am asking this question because the motivation behind creation of these verification IP and why one should need them is not clear.
- sstrell
For synthesis vs. the BFMs, which are only for simulation.
- KennyT_altera
Sstrel is right, this IP usually is use for simulation purposes.
You may take a look the user guide https://www.intel.com/content/www/us/en/docs/programmable/683609/21-3/data-pattern-generator-and-checker.html
And we also have design example here:
https://community.intel.com/t5/FPGA-Wiki/Cyclone-V-ALTLVDS-Design-Example/ta-p/735385
- KennyT_altera
Not sure if you have further question on this? If no, we shall close this thread.
- KennyT_altera
We (Intel) have “logged-out” from the post as we do not receive any response from you on the previous question that we have provided. You can “Bring It Back To Our Attention” by logging in here ‘https://supporttickets.intel.com’ and reply within the next 15 days for further support.
