Worst case, it just wont work. Possibly worse, it works sometimes and then fails, then works again.
That's mean there is no design can allow illegal clock exist?
I guess so... Initially, i still thought is not a critical issue to have this... - Altera_Forum
What's it on? If it is something that you don't care about, then it doesn't matter. Although not ideal and maybe not "good design practice", I've seen plenty of designs with unconstrained/illegal clocks that work fine. If it needs to be constrained, then it should be constrained. W
Thanks a lot for you guys reply.
I think i will need to look further to solve this problem :)
