15 years agoWhat is the ds_MISO signal in my SPI?
Hi, I've implemented several SPI (Alter IP) interfaces in several SOPC systems. Today, I made another one and this time I found an additional port that I don't know about. It is called ds...
15 years agoi've seen this before, as i recall you can comment out the 2 lines containing ds_MISO in the generated HDL. i think it was fixed in later versions (which are you using?)
