IDeyn
Contributor
7 years agoWhat is the best way for a manual routing in Quartus?
Hi all. In a quite a rare circumstances, there is a need for a manual interconnect resource choosing. For example, in case of oversampling scheme (the situation where a signal feeds multiple registe...
KennyT_altera
7 years agoHi Ivan,
Are you using Quartus Pro version, we have a new option call fractal synthesis to handle this type of case.
It allows the Compiler to apply dense packing to arithmetic blocks, minimizing the area of the design.
You can enable it in the assigment editor. this option is not support in Std version. You have to use the way above to manually assign those node.
Kenny
IDeyn
Contributor
7 years agoHi Kenny.
Thank you very much for your answer.
I know about fractal synthesis and it is not what I mean I suppose.
Maybe my screenshot is misleading, it can be not just MLAB but any element as a value of "Location" Assignment - LAB combinational cell or delay chain or so on.
The answer that you gave is not about routing elements selection, it is about math blocks packing for area at the previous step of compilation - at Synthesis.
So my question is how to choose manually routing resources. As an example I added another screenshot from TimeQuest GUI -
Here I highlighted Routing Element type in timing path.
Ivan
