10 years agoWhat is point to point pin assignment in Quartus assignment editor?
What does "point to point assignment" mean in the FPGA design and why do you need to assign a pin for a path? I tried but failed to find a comprehensive tutorial/document (apart from Quartus ha...
10 years ago --- Quote Start --- In the assignment editor, you have "from" column and "to" column, so when you specify nodes for both columns, this is a point to point assignment yes? --- Quote End --- Altera engineers have done their GUI for assignment editor that way; a spreadsheet table containing "from" column and "to" column. The two columns only apply for a path with source/destination. But for some assignments it doesn't make any sense obviously such as pins as you found out in which case one column applies(to). There are many others e.g. current strength or io standard. So it is matter of fitting in and a lazy shortcut from Altera's GUI engineer.
