13 years agoIf you cannot change the source of the clock driving the PLL due to fixed pins, keep in mind that this is a warning, not an error. If you run "derive_clock_uncertainty" in TimeQuest and look at the uncertainty on the output clocks from the PLL, if you can live with this level of uncertainty, then you can ignore this warning.
