13 years ago --- Quote Start --- But how to decide a pin which can make the PLL happier? --- Quote End --- The device handbook described the PLL and clock resources. --- Quote Start --- The problem is the evaluation board has some specific pins which connected with FPGA chip, are clock signals for FPGA. In my system, I need a main clock. But a PLL is not happy with this main clcok pin, how can I handle this problem? --- Quote End --- Which evaluation board? Most evaluation boards have a 50MHz oscillator routed to several CLKIN pins. When dealing with an evaluation board, you sometimes have to make a judgement call, eg., if the clock frequency you are creating in the PLL is low enough, and you are using the PLL output only as a digital clock (not an ADC or DAC sampling clock), then you can probably ignore the error. At a minimum, if you do ignore the error, you should download the configuration file and test whether or not the clock jitter is a problem. Cheers, Dave
